SOURCE: DVD Player stopped working... will not LOAD/PLAY dvds
its the problem of fuse in the main board of the unit.due to which shut off and in that shut off the lens got faulty which needs replacement.as the faulty lens cannot load or play disc.
SOURCE: code to program polaroid vcr/dvd combo and a new sharp lcd tv
Try 1061 or 1020 hope it works.
SOURCE: a dvd is stuck in the dvd player of my polaroid
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
