Cut the t.v on blue bscreen tried clicking input button but got nothing but a blue screen.
SOURCE: mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
SOURCE: Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
SOURCE: Mitsubishi 56231 Turns on but no picture or sound
HEY DJ SOUNDS FAMILIAR TO ME AS THESE SETS SEEM TO FAIL IN THAT WAY WHEN THE CAPACITORS IN THE POWER BD. AGE/WEAKEN.I PROPOSE A CALL TO A MISTUBUSHI EXPERIENCED TECH THAT CAN REPLACE THE 6 CAPACITORS AND YOU/LL BE WATCHIN' HD AGAIN. JOE TV
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
SOURCE: my picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
