Dryers Logo
Anonymous Posted on Apr 25, 2012
My dryer will not start
I tryed bypassin the start switch to see if it was the switch but that didn't work also checked all the electrical and it also looks good the beltis also still there so now i'm stomped
Justin Duby
Level 2:
  • Expert 370 Answers
  • Posted on Apr 25, 2012
Justin Duby
Expert
Level 2:
Answers
370
Questions
Helped
166259
Points
897
Make sure your door switch is clicking and if it is... Heres the problem. The problem is that the Thermal Fuse is blown. This keeps the motor from starting. Take the back off your dryer and locate the fuse on the blower housing. (Loacated lower left) The fuse is about a half inch wide and 2 inches long. It should have either 2 blue or orange wires running to it. Check this part for continuity with a multimeter. This is for dryers with the lint finter located on the top and not in the door. If your filter is in the door, let me know and i will tell you how to repair it.
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 22, 2007
SOURCE: Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Anonymous
  • 185 Answers
  • Posted on Mar 25, 2008
SOURCE: Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Anonymous
  • 172 Answers
  • Posted on Aug 12, 2009
SOURCE: control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Anonymous
  • 172 Answers
  • Posted on Nov 17, 2009
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Anonymous
  • Posted on Mar 20, 2010
SOURCE: MAYTAG PERFORMA ELECTRIC DRYER WONT START
Same thing as other owners above...Dryer is five years old and is in need of a good cleaning of lint build-up. Model no. PYET444AZW.
I put a large load of clothes, which probably should have been spun again, into the dryer. When I returned the clothes were still basically wet, and the light in the dryer would not come on, and nor would the dryer start.
Tested the circuit breaker. OK. Tested the outlet with a tester pen. OK.
So in searching the internet for a solution, I found and read this string. Found the fuse, called my local appliance parts store and bought a thermal fuse kit for CDN$48 (incl sales tax). Kit came with three fuses.
Just opening the top of the dryer was a chore for a complete novice. However, the entire top is hinged at the back -- so at the front of the machine, just gently poked a slot screwdriver in the gap ringing the sides near the top, twist screwdriver and lift. Big fuse is easily accessible at the top near the back of the drum. It's a round thing about the size of a quarter screwed into a metal frame with two crimped-on wires coming out the top. One screw to removed the frame. Then detached the crimped-on wires, and removed the fuse from the frame with two more screws. You will need a smaller size ratchet or nut-driver.
While you have it apart you might as well change the second nickel-size fuse, too, although it is more of a pain.
You have to remove the coiled elements, which are basically just big springs. They come out with one screw on the right and a little finesse. The second fuse sits on the right-hand side of the metal box surrounding the coiled element. The screw for the coil also held the frame for the fuse in place, but the frame will still be secured to the box with a couple of small tongues. So you will still need to kind of lift and pull up on the frame housing the fuse. It requires some patience and finesse. Remove the crimped-on wires, and change the fuse.
Of the two smaller replacement fuses that came with the kit, there was one marked for a gas dryer and another for electric. (The big fuse was good for both.)
Then start putting it all back together. Took me two hours in all. But now that I have done it once, it would hopefully take me only 30 mins. now.
Finally, my replacement instructions suggested cleaning out your machine and removing the lint and other burdens which probably overloaded the fuse in the first place. So I bought one of those specialized lint brushes to clean out the trap and the exhaust hose and vent.
Amana Electric Dryer
You lucked out there but better replace that start switch because it will do it again just when you don't want it tol
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Have a GE electric dryer model DJXR433EC2WW. Whenever I select the dryer mode/time option, the dryer turns on by itself without turning the start switch (door closed). The dryer only stops when it...
I have seen that in those dryers before and it has always been the motor that is causing it to start without engaging the start switch.
GENE
Sep 16, 2011 • GE Dryers
My zanussi dryer has been working for four years and now its suddenly stopped. I tried cleaning the condenser which didn't work.How will i get it in proper condition again?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have a duet electric dryer GEW9250 about 5 years old. It stopped working last week. The light inside works but nothing else (no control panel buttons or lights or the digital display). A repairman...
Hello there and thank you for choosing fixya
To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 • Dryers
Dryer is not blowing hot air. There was water collecting in the vent hose which was emptied, but didn't help. Probably a heating element but not sure.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';';'
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
