Handspring Visor Pro Handheld Logo
bart scott Posted on Apr 25, 2012
How do you uninstall programs on a handsrping visor pro
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
59
Points
12
The Palm OS is pretty straight forward. So, in the homescreen, the top drop menu it's App/ Delete.
Good luck !
Uninstalling Cakewalk Pro Audio 9
install cakewalk pro again,,,then uninstall..
Recently purchased a new computer with window 7. Ouickbooks 2008 installed ok but within a week I got the message a file within the program should be replaced. I tried to uninstall QB 2008 but it will not...
Welcome to Fixya
To uninstall the QB 2008 program. Click start menu then click control panel. Go to program and features icon and search the quickbooks 2008 program. Highlight it and click uninstall on top. Wait until the program will be uninstalled to your system.
Thank you for using FIxya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I downloaded Share Bear Pro onto my laptop, but now I cannot uninstall it fully. I try to uninstall it, but it says something like "this program is still running and this program is still in...
first right click the taskbar and click on task mamager
then clcik the bearshare application and force it to shut off by clicking end process
once you have done this you should be able to uninstall the program
2answers
Want to uninstall Iris Card Pro 4 from computer
if there was software installed onto your computer for this device then it should show in Control panel->add/remove programs (xp) or control panel ->programs and features (vista/7)
Simply highlight the line which refers to the software you wish to remove then click uninstall.
Hope this was helpful.
Can not program visor mounted garage door opener. Help! Opener is a Genie, followed directions no dice.
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: MOST BUT NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
You must read and follow the instructions very carefully.
After you program the visor you must then program the opener to accept the visor code. Press the learn/memory/program button then press and hold the visor button (within 20seconds) the next time you press the button the door should move.
HOPE THIS HELPS
1helpful
Handspring visor pro on Vista
The easiest way to do this is by usb. You will need to download the 6.2 palm desktop/hotsync manager (yes, it says it will not work with your prism... I know.) Then you'll need to download pimlico's palmhotsyncsetup tool, that will allow it to work.
You can read the full instructions and get the appropriate links here:
http://forums.palm.com/t5/Windows-HotSync/Windows-7-and-Vista-hotsync-instructions-here/td-p/251755
1helpful
2answers
Cannot uninstall Defender Pro antivirus program from my Dell
A lot of programs do not get listed in the Install/Uninstall applet in control panel. For these programs you can usually go through the start menu to the program in questions and usually there is a shortcut/icon in there for Uninstall.
Cannot uninstall WinFax Pro 10 even after doing manual uninstall.
For the next 12 hours you can download for free cleanse UnInstaller Pro At Giveaway of the Day. Install it and then keep attacking every bit of Symantec you find on your computer. You may have to go back several times and keep on deleting more pieces of the programs that were there but this truly works. It's the only program I found so far that could get rid of WinFax Pro including the stuff provided by Norton. Good luck
Can i sync a handspring?
Recent version's of the HOTSYNC app have a provision for IR transfers (older versions may not though). So you should check the HOTSYNC app on the Visor and see if it already has IR transfer abilities. If it does: Use the downarrow to specify the IR transfer on the Visor. Setup HOTSYNC on the computer to accept IR transfers. Line up the ports and tap the HOTSYNC button on the Visor's display. If it doesn't: You may be outta luck. Downloading an updated version of the HOTSYNC app (or some other utility) won't help because you'll need to Sync in order to get the app on the Visor.
Top Handspring Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
