All settings seem good
SOURCE: Photocopier 7013
You must reset in his menu! Go in setup menu or status menu and there
must be reset Drum unit!!! But it's not the same cartridge and drum
unit!!! It's separate part's!!! Give me exactly message!!
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
SOURCE: Black pages when printing
Are the lamps comming on, and on brightly? They may need replaced.
You may also have a bad ground contact to your drum cartridge.
Remove the cartridge and clean the contacts. The ground contact may also be worn out.
Those are the 2 most common problem with black copies on that machine
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
