Question about Toshiba Computers & Internet
Toshiba Satellite Pro 4600 laptop
Which keys to reinstall from formatted hard drive?
    Top Expert:
  • 5,051 Answers
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
Posted on Apr 26, 2012
5 Suggested Answers
Atiq
  • 256 Answers
SOURCE: Toshiba satellite pro 4600 PS460A-D216R
your 700mhz will be 100fsb and 1000 will be 133fsb, if your mainboard support 133fsb then you can. check you mainboard is intel 810e than i will support.
Posted on Mar 22, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: loud clicking
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Posted on Jul 24, 2008
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: Lost installation cd
ask toshiba to send one for a nominal fee.
Posted on Nov 29, 2008
Anonymous
SOURCE: Toshiba Satellite Pro 4600
Any driver that you are left without - try running the 'Unknown Device Identifier'.
It'll scan your Devices List, identifying ALL the information for each, rather than simply its name. You can download it from here:
http://www.zhangduo.com/udi.html
Posted on Feb 02, 2009
Anonymous
SOURCE: Satellite Pro 4600 SOFTWARE CD
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?selModel=1073792275|PS460U&modelFilter=4600&rpn=PS460U&category=&selCategory=3&moid=1073792275&os=&ct=SB&selFamily=1073768667
This is all you need, for any operating system ! If you need any more help, this is my yahoo mesenger ID : szasz.hunor
Posted on Feb 18, 2009
Format acer aspire V5-571p what is the key number to format ?
To format a laptops hard drive you have to use a OS installation disc or a boot-able format tool. If you are going to reinstale windows you can formate the drive from the windows instalation disc.
Dec 24, 2013 | Computers & Internet
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
How to format a compaq
Formatting is used to erase yourhard drive. Many times, this is used to clean a hard drive after a virus or toperform a completely clean installation of a new operating system. A Compaqlaptop can be easily formatted, but formatting will only solve system problems,not hardware problems. The process should only be used to solve problems as alast resort, since it will erase all of your data.
1. Back up all data before performingthe format (if possible).2. Insertthe operating system disk and restart your computer and wait until prompt fromthe system.3. Strikeany key when prompted to begin running the disk.4.Choose between reinstalling yoursoftware or repairing. Reinstalling will allow you to format and thenreinstall. Repairing will bring you to a DOS menu. You will need to use FDiskwith each individual drive letter on your hard drive. Use this option if youhave a multiple partitions on your drive and only need to format a singlepartition.5.Choose "Full NTFS" formatif you choose to reinstall the operating system.Remember:Most users will only need to use thereinstallation option. This option is perfect for users with one partition orthose reinstalling or upgrading their operating system.
Never format your Compaq laptopwhile on battery power. If the battery dies during the format, you could ruinyour hard drive.Hope this helps, pleaselet me know if you need further assistance.Please don't forget to rateand comment if my solution was helpful, thanks!
Aug 07, 2012 | HP Compaq FS7600 17" CRT Monitor
Toshiba Satellite Pro 4600 laptop - which Keys to reinstall all windows after a formated hard drive error?
Do you have the Recovery Disks? I hope so because if you reformatted the drive you wiped out the Recovery Partition.
Apr 25, 2012 | Computers & Internet
How would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
How to format compaq laptop nx6110
Hi
you could try to do this
Please try to save any files or pictures that you need before you do this either to a usb spare hard drive or a usb pen drive because you will loose it all if you format or reinstall windows
press the power on key as well as the F11 key
hopefully this will take you into the factory restore
which will format the hard drive while it restores
if you just want to format the hard drive itself then you could remove the hard drive
connect it to another computer via a usb cable and use the other computer to format the hard drive that you removed
or there are some good software out there that you can bootup with and format your drive without removing it from your laptop
a bootable spotmau would do the trick but its not cheap to buy
norton system works is another good software
pleasse let us know if this has helped you
many thanks
Jul 08, 2011 | HP Compaq nx6110 PC Laptop
Unable to access safe mode using f8 or msconfig because a virus has exe,
try to scan ur system using your anti-virus or if still not work you need to reset it to its factory default or reformatting your HDD...
How to Format a Computer with Windows Vista
To format your hard disk during Windows Vista installation, you'll need to start, or boot, your computer using the Windows Vista installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows Vista installation disc, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, follow any instructions that are displayed, and then click Install now.
    • If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start Windows from a CD or DVD.
  5. On the Get important updates for installation page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.
  6. On the Type your product key for activation page, do one of the following:
    • If you are reinstalling Windows Vista, you should enter your product key now.
    • If you are not reinstalling Windows Vista, you can skip this step.
  7. On the Please read the license terms page, if you accept the license terms, click I accept the license terms.
  8. On the Which type of installation do you want? page, click Custom.
  9. On the Where do you want to install Windows? page, click Drive options (advanced).
  10. Click the partition that you want to format and click Format
    • If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format
  11. When you've finished formatting, click Next.
  12. Follow the instructions to finish installing Windows Vista, which include naming your computer and setting up an initial user account.
    • If you do not want to reinstall Windows Vista, you can cancel the installation at this point and keep your newly formatted drives.
Oct 03, 2010 | Computers & Internet
I just received the system and recovery dics from Acer. When I insert the system disc, it loads and then times out with "please wait a moment..:
Then you may have a faulty hard drive, you didn't say why you had to get them, what happened? If your drive is OK? Then perhaps you need to format it first, with say UBCD, here download and burn to CD, and it has tools that will allow you to format and partition. www.ultimatebootcd.com/
Official instructions below.
Turn on you computer, if not already done. Place the Recovery Disk into your CD Drive. Restart the computer with the disk in the drive.
While the computer loads, you will be prompted to "Press any key to boot from disk." Press a key quickly as you are only given a few seconds to do so.
Follow the instructions on the screens to format your hard drive. When prompted to format the partition on your drive or to alter the partitions, select "Format" with the arrow and enter keys. Selecting "Alter" will not recover your computer.
Once the format is complete, you will be prompted to restart your computer. Accept, and while it boots again you will be prompted to "Boot from Disk," as in Step 2. Do not press any buttons this time as you have completed the formatting process already.
Windows will be reinstalled once formatting is complete. Remove the Recovery CD from the disk drive. Replace with the Driver Installation CD. Reinstall all your computers drivers with this CD.
  • If you accidentally select the "Alter" option in Step 3, restart your computer using the button beneath the Power button on your computer and follow Step 2 again. Store any files you want to keep on an external media, such as a CD or external hard drive.
  • You will lose all saved information on your hard drive, since using the Recovery CD will set your computer back to the factory default. Do not unplug or turn your computer off while the formatting or installation is in progress. Doing so may corrupt your hard drive and might render it unusable.
Feb 27, 2010 | Acer Aspire 5100-3357 Notebook
Need to factor reset,|NOT REBOOT, for acer aspire 3630 windows xp
Hi and welcome to Fixya..
Reinstalling Windows XP on an Acer Aspire 3000 is fairly straightforward. You may need to reinstall Windows XP due to hardware failure, a virus infection, major hardware changes or a hard drive upgrade. Whatever the reason, you can do the reinstall yourself at home. The reinstall will take anywhere from 1 1/2 to 3 hours, depending on the size of your hard drive. Be aware that reinstalling Windows XP will format your hard drive, getting rid of all data on, so you'll want to back it all up on a media device.
  • Step 1
Back up all data on your computer before reinstalling.
  • Step 2 Insert the Windows XP disk and restart your computer.
  • Step 3 Press any key when prompted to begin running the disk.
  • Step 4 Press F8 to agree to the terms of service.
  • Step 5 Choose the partition you want to reinstall Windows XP on. This is usually "C:" for most users.
  • Step 6 Choose the type of format. You can choose either "Quick" or "Full" for NTFS systems. A quick format only takes a few minutes less than the full format.
  • Step 7 Wait for the format to complete. The Windows XP installation wizard will begin. You will be asked to choose your time zone, computer name, and to input any network information. Otherwise, the reinstall will run by itself.
  • I hope this helps
    Oct 15, 2009 | Acer Computers & Internet
    Abit Guru Ai7 Hard Drive Problem
    Simply....... no. Once formatted it's reinstall time.
    You can load you're windows cd into the cdrom drive & try to get windows to load. If you do get the cdrom to load - (Press any key to load from cd...... ) & press any key. Once in windows setup ( DO NOT format the drive) but do reinstall windows, if windows see's another windows on your drive, great install over it. If windows does re-install it's self you should have enough time to install burner software & back up your personal data to CD or DVD before your partition looses it's cookies & shuts you down.
    You can also leave it alone & install another drive & setup windows complete & slave it back into you're system for IDE.
    SATA's are all master drives. Than copy your data back to you're new drive. In these cases I always suggest the user go to the web site of the hard drive & download the Mfg's bootable software tool's/setup utilities. Windows is not perfact at formatting.
    Luck!
    Mike
    Apr 08, 2008 | Abit A17 Guru Motherboard
    Computers & Internet Logo
    185 people viewed this question
    Top Toshiba Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
