It going to cost me $1300 so I need to do it myself. Can you replace it with out removing the timing Chain?
The oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
SOURCE: 2001 Ford Ranger V6 timing chain
Hello;
The Ford motors are pretty good. I had 280K on a 2.9 V-8 that only needed the oil changed every 3K. Unless you have fluctuatuation in the timing then you should be ok.
These engines use a chain rather than a belt and have excellent life.
Thanks;
Rich RPM Northwest
SOURCE: remove and replace 1984 ford f250 460 water pump
Water pump Install the water pump in the reverse order of removal, using a new gasket coated with sealer. Torque the bolts to 12-18 ft. lbs. Install all remaining parts in reverse order. Fill the cooling system, start the engine and check for leaks. TIMMING CHAIN
Disconnect the battery ground.
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
To install:
To replace the timing chain and sprockets:
Oil seal installation tool
Timming chain cover alignment tool
SOURCE: replace oil pump on 3.8 Ford Windstar. Do I need
water hose? its a lot more involved than that. if it needs an oil pump...it needs more than that. have a shop check it out.
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-cover-and.html
How to Remove Timing Chain and Gears on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-and-gears-on.html
Ford Mondeo ST220 camshaft Timing specifications?
http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
------------Replacing Timing Chain Cover For 2009
Ford?
http://repairhelpcenter.blogspot.in/2012/03/replacing-timing-chain-cover-ford-2009.html
Timing Chains & Front Cover Removal on
2008 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/timing-chains-front-cover-removal-on.html
----------How to Replace Timing Chain Cover, Chain,
Sprockets, & Seal On Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-cover-chain.html
---------How to Replace Timing Chain &
Sprockets on Ford Windstar?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
---------Timing Chain &
Sprockets Replacing on Ford, Mercury and Lincoln?
http://fordrepairhelp.blogspot.in/2012/03/timing-chain-sprockets-replacing-on.html
Chain & Sprockets on Ford Edge and Lincoln
MKX?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
------How To Replace Timing Chain, Sprockets
& Front Cover on Ford Expedition and Lincoln Navigator?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets_356.html
---------Timing Chain,
Sprockets, Front Cover & Seal removal for Ford Mustang?
http://schematicsdiagram.blogspot.in/2012/03/timing-chain-sprockets-front-cover-seal.html
Chain on Buick LaCrosse?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-on-buick.html
---------These details will help.For more help keep updated.Thanks.
