Question about Durabrand DWT2405 24" TV
What's your problem?my duraband tv has no sound
Turned it on today no sound great picture
Posted by Jeanette Anderson on
    Top Expert:
  • Durabrand Master
  • 76,407 Answers
Check its speaker. If it is found OK, the audio output section circuit inside have the fault.
Posted on Apr 26, 2012
WHY DOES MY TV HAVE A PICTURE BUT NO SOUND?
hi put some hear phones into the tv jack see if you can hear sound this test tells you the sound processor is working, also you can test the speakers with a meter, thanks
shaun
May 26, 2017 | Televison & Video
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
Lost my controller for my duraband ptv7017 and can't select the av chanels. How can I do this without the controller ?
Hello
Without its remote control, you can't select its AV channel. Just try to get a new remote control or buy a universal remote control, which have setup codes for Duraband Tv with it.
Setup codes for Duraband are:
0189 0135 0157 0153 0254 0458 0217
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 07, 2012 | Televison & Video
How to fix a duraband tv it's nt working and red
Sounds like a bad relay or power supply. WIthout physically checking out out there is no definite way to determine what the actual issue is. Try unplugging it for 20 min and seeing if it manually resets, if not it appears like a trip to the TV repair man may be inevitable.
Nov 10, 2011 | Televison & Video
The TV 's blue light comes on indicating the TV is on but there is no picture or sound.
Hello alaws,
Welcome, and thank you for using FixYa!
Your issue will require some diagnostic from your local TV Repair Shop. In today's market, unless you find a repairman that does this work for a hobby, the cost of the parts and labor is higher than the value of the TV.
It may be in your best interest to research the LCD and LED TVs at your local WalMart/KMart/Best Buy.
Have a great day!
Sep 12, 2011 | SunBriteTV Televison & Video
No Picture, but I have sound!
Your color tube has probably went out that is why you have sound but no picture, you will have to call a tv repair place or where you bought it from to get an estimate on having it repaired
Jul 22, 2009 | Televison & Video
Norcent PT4291HD Plasma TV, no picture
The power will not stays on, it keeps turning off by itself
Dec 01, 2008 | Norcent Technologies PT-4291HD 42 in....
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Durabrand DWT2405 24" TV Logo
65 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
