The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
