I cannot load safe mode, startup repair or restore. I do get a stop code which is. ***STOP: 0x0000007E(0xC0000005,0x00000000,0x8A767864,0x8A767560).
Try running the Check Disk Utiltiy.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
I do not have a repair disc
Looks like you've got to take it to a computer repair shop.
The Check Disk utility will not lose your data. Also if you have to reinstall windows there is a way to do a repair install so you don't lose your data.
SOURCE: Windows BSOD on all restarts, even in Safe Mode
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware
incompatibility with Windows XP because all the installed drivers are
Windows XP drivers:
However, if you receive the STOP 0x7E error after you upgrade from
Windows 2000 Professional, or if you recently added a new hardware
device, this issue might be an incompatible driver or an incompatible
hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Testimonial: "Fred knew exactly what the Windows stop codes meant and what steps to take to diagnose the problem. "
SOURCE: On Startup of my Panasonic CF52, It shows the blue
This is usually a problem associated with NOD32 or Cisco software conflicting with drivers or other software. If you can get past the grey screen even once, uninstall the software and reboot. If you can't get past the grey screen at all, then you might have to completely reinstall windows :(.
I'd look for professional hands-on help in this case if you're not comfortable doing this.
SOURCE: Big issues with Vista on my Inspiron!
Did you try to "Restore this computer to another point in time"? Then you press F8, and choose "System Restore" then another screen asks if you want to go to safe desktop, or do a system restore, when you select system restore,another window, a bit like a calendar, and you choose a date prior to when you had problems?
Otherwise, please try this... when dell screen comes up on keyboard hit CTRL+ F11 twice only then you will see Dell pc restore by Symantec.Hit on restore and hit on i agree and select the option Restore the pc to dell factory settings and then it will restore the pc.
Otherwise you will have to obtain a Windows Vista install DVD, boot on this and repair/reinstall from That.. anyway try whats proposed and get back to me..
SOURCE: How do i fix the blue screen stop 0x0000007e on my
Confronting Blue Screen of Death popularly known as BSOD is one of the worst nightmares for any computer user. It can happen in all the Windows versions. Win 7 is no exception to it to BSOD. Luckily, there are ways to fix Win 7 Blue Screen of Death problem.
Usually with BSOD, one can not do any work on computer. Computer hangs, restarts or shut down on its own. There is always a great danger of losing unsaved work.
The situation demand urgent action on your part to continue safe and smooth computing.
I am sharing few tricks of the trade that will surely help you whenever you see tragic Blue Screen of Death in Win 7.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
Alternate:
or
is there a program i can download from another computer that will not affect my documents
Without a repair disc or Operating System disk you will have to take it to a repair shop.
Maybe you can borrow a disk from a friend, relative, neighbor or co-worker. Just make sure that it is for the same type of operating system that your Certificate of Authentication (COA) Sticker on the bottom of the laptop (sometimes in the battery compartment). In other words, if your COA says Windows 7 home Premium, you can't use a Windows 7 Home Basic. You might have windows xp, windows 7 or windows vista, but the disk you borrow has to match because if you have to put in the COA Key Code (the series of 5 letters and numbers on the sticker) you will have to use yours from the sticker otherwise it will not activate.
