2002 Daewoo Lanos Logo
Posted on Nov 16, 2008
I NEED TO KNOW HOW TO ALLIGN A 2003 DAEWOO NUBIRA TIMING BELT.
REPLACED VALVES AND MANY OTHER PARTS, MY HUSBAND NEEDS TO KNOW HOW TO ALLIGN THE TIMING BELT.
  • Anonymous May 11, 2010
    What size engine does it have?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1193
Points
If you have the 2.0 L engine, then the two cam marks should point upward to match the notches in the valve cover. The crankshaft notch should point downwards to match the V notch in the lip of the oil pan. Hope this helps...
1helpful
I need the timing marks and firing order for a 1998 daewoo nubira cdx 2.0 wagon
firing order 1342 timing belt alaing the mak on the gears to the block
1helpful
Daewoo nubira 2002
Please follow this link to the see the whole process with diagrams of the belt change. Please note if the belt broke you likely have bent valves.
1helpful
Does the timeing belt have to be on for the crank to turn the cam when instilling the timeing belt?
Are you replacing a broken timing belt? Or are you replacing a belt because it's due by miles? If the belt is broken, i strongly suggest inspecting for bent valves. Daewoo is notorious for bending all valves and breaking valve guides in the cylinder head when the timing belt breaks. The broken belt is also common.
4helpful
2answers
Need timeing belt diagram for 2000 dawoo nubria how to instill
CLICK HERE and HERE for timing belt information on the Nubria
Thanks for using FixYa
My timming belt broke and i replace it and i only can compression on the number 3 clyinder what do i need to do
your Daewoo has an interference engine, when the timing belt brakes the valves hit the top of the pistons, and get bent. you will need to remove the cylinder head an replace the valves.....sorry.
1helpful
2answers
I need to know how to time the engine.
hi we are in the process of replacing the timing belt on a daewoo lacetti 2004mbut we not sore on the cam timing could anyone help
Replacing timing belt on daewoo nubira 2000 model
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/2000/make/daewoo/model/nubira/2000_daewoo_nubira_timing_belt_diagram_marks.htm
7helpful
2answers
Need a picture diagram of 1999 daewoo Leganza timing belt setting or mars?
need a picture diagram for timing marks nubira 2001 2.0L
I have replaced broken timing belt on 1999 daewoo nubira and all timing marks line up but it will not idle properly and knocks
did the timing belt snapbefore you replaced it? if so you may have bent some valves. if not recheck timing marks and distributor position.
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
