Sharp 55R-WP4H 55" Rear Projection Television Logo
LITO Posted on Apr 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SHARP 55RWP4H MANUAL
WHERE IS CONVERGENCE MENU
Anonymous
Level 3:
Top Expert:
  • Sharp Master 14,553 Answers
  • Posted on Apr 25, 2012
Anonymous
Sharp Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718621
Points
48227
If it has one it is in the main menu for the set.
Words have shadows and yellow is also blue ex football game yardage lines are yellow and then there is a blue line words are not sharp
Not familiar with this particular model but it should have a convergence menu. If so, try using the convergence menu (which is basically a cross pattern (possibly multiple ones) that you use as a reference to align your colors and make the cross pattern white. When you go to this menu and see the cross patterns, if you see the shadowing of the colors, you will know what I'm talking about. If this adjustment(s) don't work, you may have a problem in your convergence board circuitry. Wish I could be of more help but try the menu.....I've fixed 2 or 3 sets like this now. Good luck!
Mitsubishi WS-65611 Repair kit from TV-Repairkits.com no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Still issue with convergence after replacing ICs
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
2answers
Sharp 55R-WP4H view timer blinking
IF THE B+ SUPPLY IS BEING PULLED DOWN DUE TO A SHORTED IC. UNPLUGGING THE CONVERGENCE BOARD MAY ALLOW THE SET TO COME ON. COMFIRMING YOU HAVE A PROBLEM WITH THE CONVERGENCE IC AND POSSIBLE IC'S.
Mitsubishi vs430ca service manual
Good Day;
You need to repair TV, sounds like you a convergence problem, but try this THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
Good Luck, big IRISH.
2answers
Samsung HCM4215W convergence problem
are you trying to move it my the controls in the menu screen or how?
2helpful
6answers
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Gets stuck on Convergence menu
i think i know what you mean. if its the screen where you try to adjust the blue and red crosses, then you should press the "av mode" button, that takes you back to the menu, but i still don't see the adjustments I thought I was making, but I didn't have to turn it off. PEACE.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
