Question about One For All URC-3445 Remote Control
Universal remote One for all URC-3445. Does anyone know what is the set-up code for Muji DVD player PDV1 and for Bush set-top-box BU11FVZS2/A.
Hello, I have a universal remote One for all URC-3445. Does anyone know what is the set-up code for Muji DVD player PDV1 and for Bush set-top-box BU11FVZS2/A. I have tried all the codes suggested in the remote's manual and the search method but my device didn't respond.
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
robotek
Graeme Ross
  • 1512 Answers
SOURCE: URC-4041 Universal Remote
you may have problems getting any replacement remote to work here(or a code for any). The company is based out of China, contact details for them can be found at http://www.made-in-china.com/import-export/eJnQVugPRxZLprofile1/Chitech-International-Ltd.html.
You may be able to get a new replacement remote direct, Hope this helps. a "fixya" rating would be great for my time spent trying to get this info for you. Cheers :)
Posted on Jan 26, 2008
Anonymous
  • 3 Answers
SOURCE: One For All URC-4640B00 Codes for Sanyo DVD Player
I found a downloadable PDF File of the manual and codes for this remote. Hope it helps.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc4605access4&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4605-manual.zip
Posted on Sep 15, 2008
Anonymous
  • 9 Answers
SOURCE: URC-4021B00 codes
http://www.oneforall.co.uk/us_US/support
Posted on May 24, 2009
Anonymous
SOURCE: Need universal remote code for Humax ND-1000C satellite cable box
Put 0 0 0 0 as a code.
Posted on Jul 07, 2009
Bush DFTA46R set top box missing receiver. Have universal remote, wondering if this sansai universal remote will work, anyone have codes?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 22, 2016 | Universal Televison & Video
What is the code for UniversalONE FOR ALL remote URC-3021BG! to use, for APEX HDCD DVD player AD3201
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Universal Televison & Video
How do I program my sony blueray dvd player tpo universal remote control urc-r6
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jan 08, 2016 | Sony Televison & Video
Hi i have lost my manual for my urc 3940 one for all remote and i am looking the codes for a bush tv and a bush dvd player and a bush bu102zrh50 freeview recorder box pls if any1 can help, thanx
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Mar 01, 2015 | One For All Televison & Video
I need the universal code for a logik lbd2000 blu ray dvd
I need code for bluray logik lbd2000
Universal remote logik lrc5n110
Jul 28, 2010 | One For All URC-3445 Remote Control
Universal URC -3445
not all universal controls work with all brands and makes.....some have a decode code inside and u can enter this code to work with ur remote.....
if not u just have to do it Manuel
Jul 03, 2009 | One For All URC-3445 Remote Control
Urc-4220 universal remote codes
Eaglescout, URC codes for Koss DVD Players may be 0143 or 0440.
dntom2000, without knowing the manufacturer of your combo player I can't check on your codes, but for you and anyone who needs a code, you can try using the URC lookup page at Philips.
http://www.urc.philips.com
Jan 05, 2008 | Philips DVDR 3355 DVD Recorder
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
One For All URC-3445 Remote Control Logo
190 people viewed this question
Top One For All Televison & Video Experts
Nick Charalampakos
Level 1 Expert
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
