I currently have a Juice 500 watt amplifier hooked up to an edge 900 watt subwoofer and a jbl 1200 watt subwoofer but the amplifier packed in and stopped working. The red protection mode light is now constantly lighting up after playing it loud and the blue power light flashes on and off about every 2 seconds. I have checked all the connections, subwoofers and also inside the amplifier and cannot see anything burned or out of place. Ive tried everything and would really appriciate if someone could at least tell me what might be wrong with it. Thanks!
SOURCE: Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
SOURCE: Amplifier power light will not turn on. subwoofers will not work.
Recheck the fuse on the amp, if the fuse is good, try replacing it anyway, if that doesn't work your amp has blown an internal component, (most likely an output transistor). it is probably cheaper to replace the amp than repair it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: Visonik 350watt Amp Doesnt Come On....
you need to wire up the rem (remote trun on for amp) or just splice the power to amp to rem
