Question about Thermador Ovens
Before oven stopped working once in a while the F1 would show up, I would restart and it would work, now nothing but a spinning temperature display and no oven top gas burners work.
You have a bad control board and oven temperature sensor. I highly recommend disconnecting the power source until the repair is made.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Apr 25, 2012
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
SOURCE: Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on May 31, 2008
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
SOURCE: Gas smell oven does not light
you may need new coupler on pilot system
Posted on Jun 23, 2009
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
Dec 29, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Aug 07, 2012 | Jenn-Air Ovens
Jul 16, 2011 | Whirlpool Ovens
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Aug 13, 2009 | Frigidaire FEB27S5A Electric Single Oven
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Mar 24, 2009 | Ovens
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Jan 05, 2018 | Thermador Ovens
183 people viewed this question
