Where is the emergency brake adjustment on the 2004 Mercury Mountaineer? Thanks.
Greetings larslabs,
My name is Dennis and I can assist you to finding your parking brake adjustment location.
1) the adjustment is located so that you have to remove your center console floor finish panel (this is the drink holder).
2) raise your parking brake lever and gently pry the plastic tabs from the center console.
3) Once you can see the park brake lever you will see a nut that is turned to adjust the lever so that it has 5 clicks when it is applied.
Glad to be of assistance and thank you for using FixYa. Please rate the solution because I can learn from your rating (and it keeps my rating up to date). Thank you, Dennis
where is the thermostat for 2004 Mercury Mountaineer located
where is the altinator on a 2004 mercury mountaineer?
2004 Mercury Mountaineer check charging system
no warning brake light
no warning light is on
