Refrigerator won't drop below 37
There is no mechanical thermostat. Turbo Air uses a set of sensors that change resistance with temperature. On refrigerator models...both the sensors will measure 29-31 kohm at +32F. The MAXIMUM series, depending on which year you have, will have one or two sensors, but they will still have that ohm reading. *Two sensors mean the one in the evap coil controls the compressor off of coil temp and the one on the wall is just a thermometer. **One sensor means it senses air temp and and controls the compressor from the return air temp and also displays the temp on the screen.
Isn't 37 ok? Check the condenser is clear and clean before replacing thermostat
