Question about HP C6280 All-in-One Printer
Hp c6280 printer works with only one cartridge (the black one)?
All my cartridges are empty and because of financial problems I want to replace only 1 cartridge, the black one and the rest to leave them in the printer.
Posted by sclaudiut on
5 Related Answers
Anonymous
SOURCE: Computer won't recognize a replaced ink cartridge
This is what worked for me today..
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One. If the issue persists, please perform the next troubleshooting steps
Courtesy of Joe at HP via an email
Posted on Nov 10, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: False error empty cartridge
HP C6280 reset:
4) Press Right arrow until "Semi full Reset" is displayed.
5) Press OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 31, 2009
Anonymous
  • 70 Answers
SOURCE: I HAVE AN HP PHOTOSMART C6280 ALL-IN-ONE PRINTER
As the printer was bought in the US the printer is meant to use the #02 cartridges.
When you decided to replace the empty cartridges with refilled ones…the place you took them to be refilled more than likely decided to replace the little chip with a local flavour, which attempt to mimic original HP cartridges #363 (or what ever the number of those cartridges is where you are now). Hence now they are rejected by your printer.
But because the printer is only designed to use #02 cartridges it will reject every other cartridge/chip that do not have an #02 programmed into them….
You could try to call HP and explain them your situation and see if they can help you reset your printer to accept a different cartridge number …
Cheers.
Posted on Nov 08, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Nov 21, 2009
Kiran Anto
  • 420 Answers
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 11, 2010
Windows 7 doesn't recogize new ink cartridge on HP C6280
I would go to HP and update the C6280 printers drivers. It sounds like there is an issue with the driver. It there is not an update then I would uninstall the driver and reinstall.
Jan 19, 2013 | Dell Inspiron Core i7 640GB HDD
Replaced empty ink cartridges in hp c6280 printer but computer says they're empty. help?
Did you remove the protective cover / tape, you re put the cartridge.
Jul 25, 2012 | HP Photosmart C6280 Printer
Windows Ink Cartridge Empty false error message.
Oct 28, 2009 | HP C6280 All-in-One Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
HP C6280 with error for empty or missing Light Cyan Cartridge
hello,,, maybe your problem is found the cartridge due to saying the cartridges is missing or empty
try to put the cartridge into other printer same your printer model of even not same but same size,, to prove it is not your cartridge problem......... i think your cartridge something have a damage
thank you hope i can help you... have a good day!!!!!!!
Jul 06, 2009 | HP Photosmart C6280 Printer
Jun 01, 2009 | HP Photosmart C6280 Printer
HP C6280 reset:
5) Press OK.
Thanks, Joe
May 31, 2009 | HP Photosmart C6280 Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
HP C6280 All-in-One Printer Logo
111 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
