Question about Sharp AR-5516s
AR 5516 SHARP COPIER IS SHOWING F2 FAULT CODE
Posted by tutulranga on
  • 3 more comments
  • Deep Burm
    Deep Burm Apr 29, 2015
    #-int-c-int-14 ok
  • Anonymous Jul 14, 2016
    ami #-int-c-int-14 ok korachi kintu thik hoyni...ki korbo akhon please help me.
    ami # INT C INT, then 25-(start), then 02 (start) korachi kintu thik hoyni...ki korbo akhon please help me.
  • Amran Hossain
    Amran Hossain Mar 20, 2017
    Replace developer
  • akmal sajad
    akmal sajad May 22, 2019
    I have done but not work
abidalimowla
    New Friend:
F2 fault code
Posted on Apr 07, 2013
  • roldan acosta Aug 21, 2013
    try # INT C INT, then 25-(start), then 02 (start)... wait until its done.
  • Andrzej Boruta
    Andrzej Boruta Nov 22, 2016
    Wiat error
laiju
    New Friend:
Sharp AR5516 photocopier error F2
Posted on Mar 19, 2013
roldan acosta
    New Friend:
Try # INT C INT, then 25-(start), then 02 (start)...
Posted on Aug 21, 2013
  • Dauda Mohammad
    Dauda Mohammad Apr 24, 2016
    is taking too much time, how long will i have to wait to come up
Marvin
    Top Expert:
  • Sharp Master
  • 85,239 Answers
Toner type error
Posted on Apr 24, 2012
Chukwudi Michael Egwu
    New Friend:
Pls it is 5516 toner replaced, developer replaced, yet it does not add toner it is fant by the side of the copy and eventually the paper all become fanty. what is the problem or what can i do
Posted on Sep 18, 2013
MALIK
    New Friend:
THIS IS DEVLOPER PROBLEM CHANGE DEVLOPER TAHN COPIER O K
Posted on Mar 17, 2014
prince Henry
    New Friend:
Write your answer...E7-16 error code in 5516
Posted on Jul 05, 2017
Subsit g.p
    New Friend:
F2-04 error code sharp ar 5516
Posted on Mar 22, 2016
5 Related Answers
suhail aabed
  • 109 Answers
SOURCE: AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
toner type error
replace the toner cartridge
Posted on Apr 08, 2010
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Sreelal Devadas
  • 66 Answers
SOURCE: my sharp AR 5516 shows
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
Posted on May 20, 2011
Ditchman
  • 22 Answers
SOURCE: sharp ar 5516 copier
Have you tried a trouble clear?
Posted on Jul 12, 2011
Anthony Karuku
  • 268 Answers
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Posted on Mar 30, 2010
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
My copier sharp AR 5516 is showing f2 what shold i do
wrong cartridge .wrong country ,crum data read problem
Oct 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
On a new installation on AR-5516 sharp copier and i used developer 205 and Toner 021 and its showing F2 40
when you install developer you must enter code 25-2 and wait for about 3 minutes to turn motor and DV unit and copier will scence ATC sensor ,then turn off and on .
May 07, 2010 | Office Equipment & Supplies
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5516s Logo
11,201 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
