Question about Jabra BT2080 Bluetooth Headset
How to repair jabra
How do you repair the jabra to a new cell phone?
chenxue
    Scholar:
    New Friend:
  • 104 Answers
Any problem you are having with the Jabra headset you should be able to correct and properly sync the headset to a wireless phone.
Posted on Apr 25, 2012
5 Related Answers
Anonymous
  • 221 Answers
SOURCE: brought new phone and need to connect ear piece
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
Posted on Mar 10, 2009
Anonymous
  • 13 Answers
SOURCE: jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Posted on Jul 15, 2009
BoraDURSUN
BoraDURSUN
  • 47 Answers
SOURCE: Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Posted on Jan 07, 2010
kozachek
Daniel Kozachek
  • 122 Answers
SOURCE: how do I pair my wireless Jabra BTS30 headset with
All that is required is to repair the headset with another phone. If you need instructions on how to place the headset in pairing mode, please let me know i will be glad to help =)
Posted on Mar 30, 2010
supertech6
John Street
  • 513 Answers
SOURCE: how can I connect jabra bluetooth to my cell phone
Generally speaking, bluetooth connects like this:
1:Turn on the bluetooth device (phone).
2: set phone to search for the bluetooth headset.
3: Turn on the headset
4: when it finds the headset (you may need to try TWICE), enter 0000 to the phone as a basic password. The two should link.
Your headset guide may specify a different password - use that.
The headset may require you to hold down a button to help the search - do what the manual says.
Posted on Apr 03, 2010
How do I pair the Jabra Cruiser 2 with my new cell phone? I have gone into settings and set my phone to pair, but it keeps saying "Device Not Found." What do I need to do on the Jabra?
Make sure both devices are set to "discoverable". On the jabra this should be done by holding the main button on the headset until it flashes.
May 23, 2011 | Cell Phones
I have lost my cell phone. I have a new cell phone. How do I disconnect my jabra stone 2 bluetooth from the lost phone and connect it to the new one?
hi jorene_crock,
You are in luck!
you do not have to worry about your old phone being disconnected from your headset! just connect the head set from your new phone like you did with you old phone :)
I hope this helps, good luck!
Mar 17, 2011 | Jabra BT125 Headset
I want to connect my Jabra 0te3 blutooth headset to my laptop fujitsu P3010 in win 7 but my bluetooth is not finding jabra. how can i pair it.
1) Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
2) Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
3) Release the power button.
4) Navigate through your cell phone "Settings" menu and ensure your "Bluetooth" or "Hands-free" section is set to the "On" or "Active" mode.
5) Choose "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
6) Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
7) Select a "Connect" or "Pair" option once the Jabra headset name displays on your cell phone.
8) Enter the default passcode by entering "0000" on your cell phone keypad.
9) Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Dec 22, 2010 | Computers & Internet
I purchased a new Iphone and my Jabra will not pair. I removed the Jabrsa connection from my old iphone and the Jabra still will not connect. How to reset Jabra and pair new phone?
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Nov 12, 2010 | Jabra Cruiser InCar Speakerphone Black
I have a Jabra hands free device and my new Samsung Impression is not finding it when I hit search for bluetooth device ... my old samsung phone had no such problem. How do I find the Jabra with my new...
clear all the names of th e devices stored in the3 cell and then click on new device and search it , it will show the new device or the name of your device , pair it and click connect -----------------------------------enjoy
May 21, 2010 | Samsung SGH-A877 Impression Cell Phone
How do I pair my wireless Jabra BTS30 headset with a new cell phone? It was paired to another phone before.
Mar 30, 2010 | Jabra Bluetooth Headset with Adjustable...
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
Got a new Nokia and need to connect it to my Jabra
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 22, 2009 | AT&T Nokia 6555 Cell Phone - Black
Brought new phone and need to connect ear piece
Feb 16, 2009 | Jabra BT250 Consumer Headset
Jabra BT125 Bluetooth
First u switch off the Jabra Headset..
then switch ON the Bluetooth in ur Cell.
then search for active devices in your cell..
while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
you must hold it for approx 15 sec..
then the jabra wil be displayed in your cellphone....
tats it....add it....
enjoy,,
Nov 28, 2007 | Jabra BT125 Headset
Jabra BT2080 Bluetooth Headset Logo
128 people viewed this question
Top Jabra Radio Communications Experts
Marvin
Marvin
 Grubhead
Grubhead
Harish  Ramaiah
Harish Ramaiah
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
