Boating Logo
Steve Posted on Apr 24, 2012
Motorguide Brute Model 756
Motorguide "Brute" mODEL 756. When the motor hits bottom or rock, the pointer gear gets out of time/direction. is there a spring or something that helps hold the pointer gear in place to prevent the gear from jumping out of time?
5 Related Answers
Anonymous
  • Posted on Sep 20, 2010
SOURCE: I need a diagram for the wiring on the pedal of a 756 Brute
Try mike'sreelrepair.com
Anonymous
  • Posted on Feb 06, 2011
SOURCE: motorguide w75 trolling motor will attempt to
Plastic steering gears are probably stripped. Metal gears are available, and are easily replaced. Contact me at [email protected]
Anonymous
SOURCE: My Motorguide W75 trolling motor has a single
That is probably the antenna for the RF remote control system. Is there a connector on the end of the wire? Contact me at [email protected]
Anonymous
  • Posted on Apr 28, 2011
SOURCE: I have a 2006 Motorguide TR109 model 9BX43GAFF. I
tr 109 with 60 inch shaft uses the #24 gator mount, 50 inch and 45 inch use the #21 gator mount. Both have the springs
Anonymous
  • 823 Answers
  • Posted on Jun 02, 2011
SOURCE: My trolling motor stopped working suddenly. It is
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Motorguide 756 brute is running backwards
Sounds like the positive and negative cables are hooked up backwards.
1helpful
2answers
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
10helpful
4answers
No owners' manual
I have a Motor Guide Trolling Motor - Bow Mount - Model-71V- 24 Volt. Problem is arrow on top of motor does not align with the direction motor is going about 100 degrees off. Any solutions? [email protected]
1helpful
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Top Mercury Boating Experts
NOEL
NOEL
jws1013
Are you a Mercury Boating Expert? Answer questions, earn points and help others
