Compaq MP1600 Multimedia Projector Logo
Question about Compaq MP1600 Multimedia Projector
Compaq mp1600 won't turn on or show any sign of life when turned on. Is it the bulb or something else?
No lights, no LED, no fan, no sound at all. If the bulb is bad would that cause this? is there any way to test before buying an expensive bulb?
1 Related Answer
Anonymous
SOURCE: I have a compaq MP1600 projected that does not
I would tell you if you pay $19.99 for the answer!
Posted on Jul 29, 2009
Compaq mp1600
please upload a fan picture and showing its model, i have thread can help you to find a new fan
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 • Vacuums
2answers
I replaced my battery and the radio does not turn on nor do the head lights. All fuses are fine. The lights show if i want to flash the brights. But nothing steady. I even replaced a bulb with no change....
Well, I guess you won't be using the radio or driving after dark
You will get the code when you spend something,
because without the scan tool it won't happen.
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
1helpful
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
Compac MP 1600
your prblem will be in motherboard or in power pack module-start to change powerpack module first then motherboard second- or pass it to good sevice center.
Top Compaq Office Equipment & Supplies Experts
Mike
Mehandi Husain ...
ray gallant
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
