How do you enter the data recovery tool to factory reset the computer from boot up??
SOURCE: Vaio Recovery Center not working
If the hard drive is full, clear some space.(run disk clean up)
locate and empty the TEMP folder.
Then
Please rate this a fixya
SOURCE: Sony Vaio VGN-SZ460N - freezes on System Recovery
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
SOURCE: I need a recovery disk for Sony Vaio VGN-NR11s/s
here is a disc made by these guys http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
both 32bit and 64 bit
in your case the VGN-NR11 is 32 bit
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
which operating system ?
hope this helps
