Samsung Prostar DCS-24B-LCD Corded Phone Logo
Unblock caller id review on 24B keyset dcs
I need to be able to scroll through the caller id for all incoming calls. I do I change the settings on our phones so that it will store all incoming calls to be viewed at a later time.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jun 23, 2007
SOURCE: samsung lcd 12b keyset dcs
http://www.tel-programmer.com/Time%20setting/samsung_time.htm
Anonymous
  • Posted on Nov 19, 2008
SOURCE: How to change the voice mail message on KP DCS - 24B LCD samsung
I have the manual for the DCS series and there is no help regarding this.
It does say how to turn from auto to manual and make sure that the time is correct.
1. If the manual NIGHT key is pressed BEFORE the system automatically enters night service then the automatic night service timer tables will be overriden until the system is manually restored to day mode.
2. If AFTER the system automatically enters the night service tables and will not be overriden.
Anonymous
  • Posted on Dec 18, 2008
SOURCE: How do I change the name on my Samsung Prostar DCS 24B phone?
To Program an extension name:
1 Press the TRSF key and dial 104
2 Enter the name using the dial keypad like you are texting
When the next character you want appears on the same key press the volume UP key to move the cursor on space to the right.
To make any changes press the volume DOWN key to move the cursor to the left .
If you want lower case letters press the A key brfore entering letters.
3 Press the TRSF key to store the name
HTH
Jo
Anonymous
  • 63 Answers
  • Posted on Feb 07, 2009
SOURCE: Samsung LCD 24B Keyset DCS, I can't listen to my voicemails
delete unneededmessages
Anonymous
  • Posted on Apr 14, 2009
SOURCE: Ans/rls button...
I believe it indicates your in headset mode, and lights up when you do not have a headset button
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
2helpful
2answers
Htc touch screen smart phone does not show caller id with incoming calls any longer
my htc smart phone caller id always on .I want it off right now.Plese help me......
8helpful
2answers
How do you delete missed call message from vtech 6.0 phone
Open the caller ID screen and scroll through the recent calls. Hope this helps =]
1helpful
2answers
DCS Caller ID
You need to go into programming and turn cid on for all co lines on your c1 card and on all ext's that you want to show cid on incoming calls. Follow these steps :
to enter programming, you can use any display phone. Without picking up the handset.
press transfer
dial 800
passcode = 4321 (if it has'nt been changed)
press 1
press the speaker btn
dial 312
you will see 201 . press the ans/rls key, this will change where the 201 was to all
use the volume arrow up to change to CID ALLOW
press the right softkey (this key is the triangular key under the display just to the left of the scroll key.
Now, press the speaker btn and dial 414
you will see 701 in the top left of the display .
press ans/rls key. this will change 701 to ALL
press the volume arrow up to change from normal to cid trunk
press the right softkey under display .
press transfer to exit programming and you should have
Caller ID.
1helpful
Caller ID indicator
Caller ID indicator is probably a new call notification. You should be able to review the incoming calls list even if you do not have caller ID to stop the light from flashing.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
