My Phillips HTS6500/37 home theater system stopped working last week. It is past the warranty period by at least 2 years. I purchased a new system but would like to use the Phillips sono speakers on another stereo, both are 8 ohm speakers, but the CS6500E speakers have a custom 6 wire connector. Green, yellow, orange, red, brown and black wires. How do I connect the wires together to end up with 2 wires, like normal sound systems?
SOURCE: Can I use this subwoofer for a home theater system
yes you could but you would need to soder and take the stuff apart
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
SOURCE: I have cyber acoustics computer speaker system
Hey mate, i am sorry i do not have a complete diagram with me, but i can help you with a website from where you can get the complete wire diagram for the speaker that you want.
http://www.schematics.ca/
Try this out.
Rate me please if it helps.
SOURCE: jayco camper has 6-plug connector------car has
It would be easiest, and best, if you were to upgrade the cars' trailer connector. The 4 way just supplies brake, parking, turnsignal, and a ground. The colors are the same on the 6 way, but 2 lines are added, usually for a electric brake controller and aux. circuit. Be careful about using the battery line (Red) on the 6 way connector unless you are also upgrading the white wire to a heavier gauge (at least the same size as red).
Green - Stop and Right Turn Signal (4/5/6/7 way)
Yellow - Stop and Left Turn Signal (4/5/6/7 way)
Brown - Running Lights (tail, side, tag) (4/5/6/7 way)
White - Ground / Negative (4/5/6/7)
Blue - Electric Brakes (5/6/7 way)
Red - Aux. charge line for emergency break away, battery charger, etc. (7 way)
Purple - Aux. backup lights / other purpose (7 way)
