Question about Maytag MHWE200XW Washer
E2 f9 error code on maytag 2000 series washer
4 Related Answers
Anonymous
SOURCE: Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
[email protected]
Posted on Jan 09, 2008
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
Posted on Sep 11, 2009
livewire874
Alf Hopkins
  • 618 Answers
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Posted on Nov 20, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Posted on Dec 27, 2010
Whirlpool model wfw9050xw00 error code F9 E2
Hi, the E2 F9 error means that the communication between the pump and the control board is failing. It could be a bad wire connection between the pump and control board, or your main control board is bad and needs to be replaced. First you'll want to check for a clog in the drain. You can easily youtube how to.
Best of luck.
Ned
Maytag washer 2000 series model YMHWE251YL00. Does not finish final spin cycle. Error codes F9 E2. Please help!
If you go to web site for clarification of the codes you will know exactly where to look in your machine. If not finishing spin cycle there may be an issue with the belt drive that spins the drum to remove water.
What do the error codes F3 E2 mean on my Maytag 2000 series front load washing machine?
F3 E2 is an indication of a water temperature sensor (NTC) error, or heating circuit failure. Check the water temperature sensor and check connections to the water temperature sensor.
Several people having this error needed to repair one of the wires to the sensor. - "There were 2 black wires that go to the water temperature sensor. The wires passed through 2 tie wraps that bonded them to a flange off the bottom of the washer drum. They were wrapped with electric tape inside the tie wrap. Prior to joining the bundle of wires that went to the motor, there was one more tie wrap around the 2 black wires. At this tie wrap there was no electric tape to pad between the wires and the tie wraps. One of the wires was nearly severed.
I replaced the wires. Tie wraps should not be used. They are often too tight and crush wires. Especially in a device that inherently has LOTS of motion."
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/484867-maytag-washer-mhwe201ywoo-error-code-f3-e2.html
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 • Dishwashers
Duet washer f9 e2 code
Hi, Switch power off. Remove plug from socket, wait awhile then restart, as if first time use. If error persists try to contact manufacturer. All the best.
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Maytag MHWE200XW Washer Logo
Top Maytag Washing Machines Experts
Jessie Goss
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
