I just Bought it and it stalls. Buttons wont work. I think it needs to be reset.
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
SOURCE: Timex IndiGlo Ironman Triathlon - bell stopped working
You have lost the coilspring wich connects the watch mechanics with the speaker integrated in watch caseback. This is why you do not hear any sound but still can see the icon.
Check the area where you made the battery replacement very carefully- you may find that tiny spring. Use the magnet if necessary.
If you can not find it, go to the nearest watchmakers shop and ask to supply the new coilspring.
Do not forget to rate, please.
SOURCE: how do i reset my
There are only 4 buttons. One of them will put you into "reset" mode, but which one? Before you guess, here is the trick: you have to hold it for a couple of seconds (you don't want it resetting accidently, right?) Ok, so start with your 1st guess (ok, pick top left) did the display give you any clue that was the lucky button? (ok, the display --the seconds, will not increment, but instead will just flash the same number) You are over the hurdle...if not try another one of those 4 buttons. Once you get the seconds to flash, you now have to somehoe reset whatevaitwas you needed to reset. Which means you need to pick another button...such fun! Pick the bottom right one and look for the hour display to flash (if the light comes on, this is the wrong button...you know that) and once it does you have found the "mode" for resetting the hour. So only a couple of buttons left: pick one to see if it increments the flashing hour hand (if the light comes on...you know what to do) and push it till you like the hour number. Then push the first button that started you on resetting this thingie to let the watch know you are done messin with it.
Now you are set to fix your daughter's watch...or your grand-daughter's watch...You B so smart now...you can fix anything!
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
