Insert a new memory card micro sd 8g
SOURCE: memory card error
Did you format the card before using it on your camera? Try using a memory card reader instead of the printer's SD card slot to transfer the video. Also check if the memory card is locked (check the position of the yellow slider at the right side of the card). If this does not work, then you will have to format the card. Unfortunately this will erase all the data in your card.
Posted on Feb 04, 2009
SOURCE: I have a Panasonic Lumix
Hi I think it may be because the recommended size card is about 1/2 gb and check out your amnual or go to a web site which allows the downloading the manual
Posted on Mar 05, 2009
SOURCE: I just put a brand new 8GB Sandisk SDHC card in my
Guys you have to have the camera format the SD card itself for best results and compatibility.
Posted on Apr 27, 2009
SOURCE: Sammi James - number 1 spammer expert on FIXYA
Iam sorrie but try a other sd card and it will work..
Posted on Jun 19, 2009
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
