Question about Frigidaire PLEB27T9DC Electric Double Oven
What are the outside dimensions of the Frigdaire double oven model RBE-97N
This is the OLD Double oven in wall, Probably circa 1970
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
robert samples
  • 1314 Answers
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Posted on Feb 13, 2008
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: how to calibrate double wall frigidaire ovens.
plaese post model number to assist you further. directions for calibration should be in user manual..
Posted on Feb 21, 2009
rajak2009
Asfiya Ahamed
  • 527 Answers
SOURCE: F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 15, 2009
Dimensions of whirlpool wall double oven Mod. rbd275pdb12
Sears Parts Direct has the Installation guide for the Whirlpool RBD275PDB12 here: https://www.searspartsdirect.com/partsdirect/user-manuals/rbd275pdb12-whirlpool-parts-manual . The recessed dimensions are 49 1/2" high x 25 3/8 wide x 23" deep. The visible portion of the double oven is 51" high x 26 3/4" wide. The dimensions of the Whirlpool double oven are given on page 2; below the oven dimensions, you will find the dimensions for the cut-out box to ensure proper air circulation around the double oven. The direct link to the guide is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0409153.pdf .
I hope this helps.
Jun 06, 2018 | Whirlpool Ovens
Need installation measurement dimensions on a jenn Aires double wall oven Model #W30400S. I need to replace it
Google make and model and down load installation Manuel it will be in there .
Jun 01, 2017 | Ovens
How do I get a user manual for my Whirlpool AKP802WH Genesis circa fan oven built under double oven?
Do you know about how this unit is? I tried the model number you posted on two different websites and they came up with nothing. Either it is too old or you do not have the right model number. Sorry.
Apr 07, 2015 | Whirlpool Ovens
How many watts does my oven use?
The wattage will be on a plate on the outside of your appliance! Probably on the back or side! The wattage will depend on the country of use!
Dec 31, 2014 | Kenmore 30" Electric Double Wall Oven
Loud cooling fan on my docs wall oven
Could be the bearings in the fan motor are going. How old in the oven? You will probably sooner or later have to replace the motor
Oct 14, 2014 | DCS WODU30 30" Double Convection Wall Oven...
The heating element on my Frigidaire RBE-97N has cracked and broken. How easy or hard is it to replace it?
I assume it is the bake element. These are very easy to replace. make sure the power is off and you can access the screws from the oven cavity. remove the screws, pull gently on the element. If the wires are long enough you should be able to disconnect them or unscrew the wires from the terminals. reattach the wires to the new element. reinsert it back in place and there you go.
Nov 24, 2013 | Frigidaire Ovens
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
GE P7 double wall ovens, electic, do they still make heating elements for this model
elements are not made by the manufacturer and generic in design
to that end you go to electrical wholesalers and taking you old elements along , see if there is a like one that fits
depending on where you are there are retailers that sell elements for just about everything and e-bay has a range of elements
you have to make sure of several things
1-- the end fittings are the same
2-- the wattage is the same and the shape is the same and --the dimensions are the same
all of this you can get by reading the description on the sellers page
Feb 08, 2018 | Ovens
Frigidaire PLEB27T9DC Electric Double Oven Logo
132 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
