I have removed the two screws at the bottom but the case is stuck and i cant see anymore screws to remove.
Follow the steps in the video to remove the back cover of Samsung 2333SW: https://www.youtube.com/watch?v=4-33fgBKI0Q Samsung 2232BW Monitor Disassembly Repair
SOURCE: Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
SOURCE: Remove cover
Its a snap together job But unless you know where to start something will snap. Try the Samsung Tech support for this product. Even if the Back light or inverter or some other do able thing is doable- getting parts may not be so easy for you. So follow their advice for service.
SOURCE: removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Testimonial: "very thanks...."
SOURCE: How to remove the back of Samsung 940MW LCD TV
You will need to take a small flat blade screwdriver and insert it between the two halves of the case and gently pry the two apart. There are latches around the case that just need a little pressure to release. Once you get a few released the rest will pop open as you pull the halves apart. We have some pictures posted on our web site at: www.ccl-la.com Look in the monitor repair section. THere are several repair guides for different brands with pictures of what the release latches look like. If you have any questions just call us at: 318-447-9040
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Testimonial: "Thank you. I thought it might be something like that, but I didn't want to risk breaking something. "
