Asked to be disconnected from virgin media,since thats all i can get is coloured horizontol and vertical lines,i got sound,but no picture,and can't get the menu on because of these lines
SOURCE: Goodmans LD3755HD Picture Problems
Let me give you Technical tip. Find "IF Block" in TV, it would be near Tuner, Open the IF Block and resold it with solder iron. make sure not to make bridges between solder points. Reason of problem in your TV is .."acostic tuning frequency drift". I dont know, how to clear my point. But I am sure, this will solve your TV's problem. Good luck.
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
