The picture is brilliant on the left but the right is linrd and miscoloured and goes black for a minute or so then goes lined,then close to perfect again then lined AAAAGH it driving me mad
If its a Plasma it uses sustain or t con boards--sustain will usually be two--one for left side and one for right.
Only boards are sold for these sets--no individual parts--discover which board drives the right side and replace it while crossing your fingers--either it fixed the problem or you have a bad display panel (entire screen unit which is fatal from a cost point of view).
Testimonial: "cheers"
SOURCE: JVC LT-23X475 flat screen TV
capacitors are most likely to blame here, there are several that most likely are on the power board and are blown if you get them replaced the tv will function normally, the heat can come from the transformer since it is not getting smooth power from the capacitors. it is working very hard to dump the spikes in the electricity. I ups backup power supply rated for the tv's wattage will help smooth power and protect your investment.
SOURCE: When screen is mostly white vertical sync is lost
replaced pdp panel
Manufacturer
JVC
Part Number
QLE0023-007
Description
P.D.PANEL
