Canon EOS 5D Mark II Digital Camera Logo
Posted on Apr 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are lenses that are compatible with the canon eos 5d mark ii
What are the lenses that are compatible with the canon eos 5d mark ii (full frame)?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Apr 22, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443943
Points
622693
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
4 Related Answers
Anonymous
  • 10594 Answers
  • Posted on Jun 16, 2010
SOURCE: Canon EOS 5D Mark II whrer is the selftimer botton
Self timer function is mentioned on page-86 of manual.
Below image is part of user manual that will help you to turn on self timer.
Thanks.
Anonymous
  • 436 Answers
  • Posted on Jun 20, 2011
SOURCE: The language on my Canon
Follow the correct instructions below based on the diagram to change the language of Canon EOS 5D Mark II from Japanese to English;
1.Press the MENU button.Different tabs are displayed on top of the screen as shown below.
2.Turn the Main Dial to select the tinualbinale_33.png Setup Tab ( The one with two dots and a spanner) on top of the screen.
3.Under this tab Turn the Quick Control Dial to select [Language] ( the third item from the top ) and press the SET button.
4.To select the desired language use Main Dial or Quick Control Dial (The current setting is indicated in Blue) and Press the SET button.
5.The desired language is set.
Thanks for choosing Fixya
  • 102366 Answers
  • Posted on Aug 01, 2011
SOURCE: how much is the lcd
If it's just the display window, then about 19USD.
http://uscamera.com/cb3-2864.htm
Doberman
  • 261 Answers
  • Posted on Nov 30, 2011
SOURCE: How to set up a wireless file transmitter(WFT-E4
Get the ATG AK1 Un-Tethered Systems
Better than Canon WFT.Simple to set-up & use.Has wireless radio flash plus dual live-view.
My Canon 5D Mark II images appear almost black. It doesn't matter which setting it is on. How to fix the problem? I have used the camera for several years & this is a new problem. Any suggestions?
If this happens with different lenses then I think you've got a repair job on your hand. If it only happens with one particular lens then it may be the lens.
tip
1080p MOV Conversion-Import/Edit Canon 5D Mark II MOV to FCP X with ProRes...
1080p MOV Converter-Transcode/Edit Canon EOS 5D Mark II 1080p MOV to ProRes 422 for FCP X <br /><br />Canon EOS 5D Mark II is one of the best DLSR made by Canon. It shoots full HD 1920x1080p videos in MOV format. However, with the high quality MOV videos, you may find that the log and transfer method on FCP X does not work for them .Therefore, In order to edit the videos of Canon EOS 5D Mark II, <b><a href="http://www.aunsoft.com/video-converter-mac/">1080p MOV Conversion for FCP X</a></b> is necessary. I googled and found Aunsoft Video Converter for Mac as the perfect. <br /><br />How to <b><a href="http://1080p-converter.com/2011/07/top-notch-mac-camcorder-conversion-tool-convert-canon-5d-mark-ii-mov-to-prores-for-fcp-x-editing/">Import and Edit Canon EOS 5D Mark II MOV to FCP X</a></b>? <br /><br />1. Transfer Canon EOS 5D Mark II MOV to Mac <br />Connect Canon EOS 5D Mark II DLSR to Mac with a USB cable. Copy the MOV files to hard drive on Mac or from outside. The MOV videos will be soon transferred to Mac computer. <br /><br />2. Load 5D Mark II videos to Aunsoft Video Converter for Mac <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">Top-notch Mac Camcorder conversion tool</a></b>. Click the "Add" button to load the MOV videos to the program. <br /><br />3. Choose output format and destination <br />Click the "format" option, and choose Final Cut Pro &gt; Apple ProRes 422(HQ) (*mov) as the output format. Click the "Browse" button to specify the output destination. <br /> <br />4. Convert 5D Mark II MOV videos to ProRes 422 for FCP X <br />After the output format and destination are set, click the convert button under the preview window, wait just a few minutes and the converted Video from <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon EOS 5D Mark II MOV Videos to ProRes 422</a></b> will be ready for you to edit on FCP X. <br /><br /><b>Tips:</b> <br />Aunsoft Video Converter for Mac can also convert videos for other softwares like <b>iMovie, Adobe Premiere Pro, Final Cut Express (FCE)</b> and various media devices like <b>iPhone 4</b>, <b>iPad </b>and <b>Motorola XOOM</b>.
Canon 5D Mark II error 80
Error Code 80 on the 5D II indicates the a
Malfunction related to the electric control of images has been detected.
Cannon EOS 5d mark 3....it is in another language...how do you change it to English. I see the answer for mark 2 but this doesnt work on mark 3?
I was able to download the manual from Canon USA for free. I could search the page for you, but perhaps you also want the manual and read it yourself? here is the link to the download page:
EOS 5D Mark III
2helpful
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 • Cameras
My 5d mark 11 camera screen appears error20 and it wont remove
Hi
Error code 20 on a Canon EOS 5D Mark II indicates there is a hardware problem with either the mirror or the shutter. The only solution is to have it repaired - or if the camera is reasonably new take it back to your supplier and get your money back.
Hope this helps
David
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Conveting SLR lenses to Canon Digital
Canon makes several digital bodies which are "compatible" with those lenses. There are some obvious problems: 1. autofocus may be an issue; 2. the light meter may have to be programmed manually; 3. some of the digital features from the body side will not work if the lens cannot do what is asked of the computer. That all aside please consider the conversion factor as well. Digital sensors are not all the same format as 35mm sensors. So some bodies will be out and other you may have to compensate (ex. 1:1.3; 1:1.6). What this really means is that for instance on a 40d body, the 500mm lens will really be 800mm (500 x 1.6 = 800). Go to the www.canonusa.com website and look at the specification for the lens mount. If there is none there (as in the 1ds MKIII and 5d) there is no conversion factor as the sensor is full frame. Otherwise the 1.6 is the convertion factor. I would also stay away from the rebels as they are really built for the newer line of digital only lenses from Canon and will not be truly compatible with your lenses. Not that they won't take great pictures they just are designed differently. My recommendation is the 5d for many reasons: construction, full frame sensor and balance between features and price. Good luck.
Jun 08, 2008 • Cameras
I have used the Canon Creative 3 program for quite some time, but now have Windows vista and it won't load. Can it be updated for that operating system/
Canon Vista compatible software now available ...with added support for some cameras, but not older ones. Go here: http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct and navigate to your camera model and select "Drivers/Software" link. RAW Codec for Vista and updates to Zoombrowzer and DPP are available for the following: EOS-1Ds Mark II, EOS-1D Mark III, EOS-1D Mark II N, EOS-1D Mark II, EOS 5D, EOS 30D, EOS 20D, EOS 400D DIGITAL, EOS DIGITAL REBEL XTi, EOS Kiss Digital X, EOS 350D DIGITAL, EOS DIGITAL REBEL XT, EOS Kiss Digital N
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
