The temp is constant 68 degrees and I can't get it to change temp
SOURCE: GE Profile PSC25 won't cool past 45 degrees
With that model that is a sign that defrost is not happening on time or the beginning of the problem. Temperatures in fresh food compartment above 38 are not safe. Look into the back of the freezer compartment and let me know if you see a frost line buildup. If yes it would be a good idea to manually defrost the freezer so you can remove the rear panel and check the defrost heater and defrost thermostat. It's also important that with this model that the problem be resolved quickly. I can help you if you want. The defrost heater will be easy to see if burned out because it has a glass tube around the heating element. If you replace the defrost heater you should also change the defrost thermostat. Fan motors going bad on that refrigerator seem to always damage the control board and if the board is replaced the the fan motor should also. Let me know if you want me to help you, Thanks, Sea Breeze
SOURCE: GE PRofile side by side Model psc23sgpass - the
Hi.
The most common cause for this problem is the defrost system. The function of the defrost system, located at the back of the freezer firewall, is to prevent condenser coils at the back of the fridge from cooling down and icing up. When the defrost system is defective you get poor cooling.
You can test if the problem is the defrost system by leaving the unit disconnected or off for 24 or 48 hours.
If problem was the defrost system, then the problem will disappear after full defrost, to come back in a couple of weeks.
Other problems that can cause insufficient cooling are compressor problems, refrigerant leaks, and depending on the model, electronic control faults.
Start doing a defrost for 12 or 24 hours.
Regards.
Ginko.
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oh, the model number PWR04FANBS
