Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
SOURCE: have 2 4+4ohm avi sl500 subs how do i wire it to
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Posted on Jan 30, 2010
SOURCE: I have the Alpine MRP-M1000
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Posted on Feb 23, 2011
SOURCE: I have a alpine MRP-M500 amp connected to 2 10
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Posted on Mar 12, 2011
SOURCE: I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Posted on Mar 19, 2011
Feb 04, 2013 | Alpine Type-R SWR-1242D Car Subwoofer
Apr 27, 2011 | Alpine Type-R SWR-1242D Car Subwoofer
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Nov 06, 2010 | Car Audio & Video
Sep 16, 2009 | Alpine Car Audio & Video
Jun 08, 2009 | Alpine SWS-1240 Car Speaker
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Feb 08, 2008 | Car Audio & Video
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Apr 14, 2017 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Dec 25, 2017 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Jul 18, 2011 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
296 people viewed this question
