Question about Kodak EasyShare V550 Digital Camera
My kodak easyshare cx6200 sdhc memory card wont work in the camera keeps saying need to format and then stops before the end?
5 Related Answers
Anonymous
  • 480 Answers
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 01, 2008
Anonymous
  • 203 Answers
SOURCE: just bought a 4gb kodak
No way-that model will not support a 4gb card-yes it may fit but camera is to0 old for newer sdhc cards-go back to 1 or 2 gb max and no problems! 4gb only work on cameras within last 2 years
Posted on May 24, 2008
Anonymous
  • 39 Answers
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Posted on Nov 28, 2008
Anonymous
SOURCE: I have Z612 Kodak Easyshare
I had the same problem when I bought a 4GB card to replace the original 2GB. When I took it back to BestBuy where I bought the camera, I was told that this camera could only use a 2GB card. So, I bought a 2GB card, installed it, and everything was fine.
Posted on May 23, 2009
Anonymous
  • 73 Answers
SOURCE: My kodak easyshare c180 wont read a memory card
You should probably get a USB card reader, take the card out of your camera, put in the card and connect it to the computer. Then try formating the card through Windows using the FAT file system (not NTFS).
Posted on Apr 13, 2010
3helpful
2answers
We bought a 4GB SD Card, but the camera fail to format the card. We've tried formatting the card on computer but it still didn't work after inserting back in the Camera.
To correct a Memory Card Lock:
one the side of the memory card is a plastic toggle switch, slide it down and up again to reset the switch and then stick it back into your camera.. see if that fixed the problem.
SD SDHC Card Problems and Fixes Card Locked Card Error No Memory Card...
My kodac wont format the sd card. it does this over and over.it says format but wont format
What model Kodak camera? Are you sure you have an SD card, 2GB or smaller? Many Kodak models won't work with higher-capacity SDHC cards.
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
2helpful
2answers
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
1helpful
My Kodak EasyShare DX4530 is not formatting. I got a new memory card for it and it isnt formatting to it, it trys to but just keeps doing the same thing over and over, "memory card needs...
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards.
5helpful
I have a Kodak Easyshare Z740 & we just purchased an 8gb sdhc SanDisk & it keeps saying it needs to be formatted it says everything will be deleted and then goes back to disk needs to be formatted...
You need to buy an SD card. the Z740 works with SD and MMC cards, not SDHC cards. While SDHC cards will fit into an SD slot, there are hardware differences which keep them from working. SD cards will work in SDHC devices but not the other way around.
Again, you need to use SD cards, which max out at 2GB. Anything larger is an SDHC card, which does not work in your camera.
4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
2answers
Kodak easyshare cx6200 memory card requires formatting
try taking the card to Wal-mart's photo kiosk and see if it works there.
Kodak EasyShare V550 Digital Camera Logo
Top Kodak Cameras Experts
Ekse
Are you a Kodak Camera Expert? Answer questions, earn points and help others
