SOURCE: XBL router problems
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
SOURCE: How to set UDP & TCP port for Echolink
First I assume that you simply posted this under "Linksys > WRT" by mistake and you are using a D-Link router.
How to set up the ports for Echolink:
In general: Make sure that your Windows Firewall is not blocking the application (see Control Panel -> Windows Firewall -> Exceptions) (details also here). You have to allow UDP destination ports 5198-5199 between Internet and PC in both directions and allow TCP (source port any, destination port 5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help!
SOURCE: how do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
SOURCE: How do i forward ports with an WRTSL54GS Linksys
open 192.168.1.1 in your web browser, the password is 'admin' when on factory settings (no username)
There will be a lot of options, You will want the Applications/Gaming section. Enter the ranges, set it to both for protocol, then enter the last number of the ip address of the device you want the ports forwarded to. For the port 47624 just enter that number in both the start and end section. Good luck!
SOURCE: PCP Port 80, 443, 5223,
you need to access you router and look for the section on port fordwarding. That is were these ports can be open.
