I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
SOURCE: Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
SOURCE: Mitsubishi WS-55605 TV has covergence problems
advanced settings and click on convergence then you need to muve manualy there soud be a big cross to ajust wit your remote contro u have to muve it with the arrows up and down or right to left good luck
SOURCE: My Mitsubishi HD 1080 Model WS-55809 - the colors
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
SOURCE: how to reset convergence? on mitsubishi ws 55511,
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
