No manual eject on Symphonic DVD player - won't eject
I don't think there's even a disk in there. When I press the eject button - either on the unit or the remote - nothing happens. No sound or anything. The remote works fine to turn on and off, switch from TV to DVD or VCR.
I'm not sure if I have the right model selected - there aren't any identifying marks on the unit.
My techie friend fixed the problem by opening the box, but I'm not sure what he did to make the eject start working again. Sorry.My techie friend fixed the problem by opening the box, but I'm not sure what he did to make the eject start working again. Sorry.
You can't post conmments that contain an email address.
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it. Joe Don
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Have you tried to clean the lazer? Or did you buy the player or DVD's in seperate parts of the country or even another country? If so, there may be a discrepancy between area codes. Don't ask me how to correct that one.
2. Switch the player off and then back on. This is necessary to clean-boot the firmware.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the eject button to open the tray. (The button is between the "Power" and "TV Power" buttons at the top of the controller.)
5. Press the eject button to close the tray.
6. Wait while the player searches for a disk.
7. As soon as the "No Disk" message appears at the top left corner do the following.
8. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller.
9. Enter your former region code (Where you bought the player) from the list given below on the number pad.
10. The region code should appear at the top left corner of the screen.
11. Enter a "9" to make the player region free. (Enter a region code if you want to lock the player to another region for some obscure or perverse reason.)
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
you must start entering the code just after the "No Disk" message is shown and before the message disappears. If you miss a number it won't work
Secondly, the REPEAT key is part of the code. All six keys must be entered smoothly as "REPEAT Region code". The entry gets timed out so you can't stop in the middle and restart. Don't bash away like crazy, just do it smoothly and briskly.
If you don't see the "Region number" the first time, don't worry. Just repeat the process. It may take about a dozen tries before you get it to work.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution... * 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and then press the "eject" button. If this does not work, turn it off and unplug the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out.. * 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing. * 3 Look for the DVD holder inside the DVD player. This device holds the DVD in place while the DVD player reads the disk. * 4 Push the stuck DVD disk toward the front of the DVD player until the DVD ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied. * 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly.. * 6 Replace the casing and the screws. Plug the player in and turn it on. Put another DVD in to test whether the player is finally working .. Hope this helps!.. Take care and please Remember to rate/vote and give us 4 Thumbs Up to continue for Helping out the Community :) .
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same
time. If you successeed in ejecting the disk before the player starts
reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
