All lights work except headlights high and low beams
SOURCE: low beam headlight /daytime light are not working
It's on the driver's side. Remove all the plastic & it's in there.Big rectangle, black box,about 1.5" thick,lotta wires.
SOURCE: High Beams, parking lights work. Have NO low beam
had same problem had to replce whole turn signal switch
SOURCE: 2002 Impala, headlights work however they blink
This may be the start of a worse problem that the Impala eventually developes. The Body Control Module has a design flaw along with the Passlock anti-theft system. You may get away with just replacing the BCM for now. It needs to be reprogrammed at the dealer and the car will not start if you replace the BCM without reprogramming it. I would also recommend against replacing it with a remanufactured one. Repair cost is going to be around $500 at the dealer.
If the Passlock system is also at fault, add another $500 for a new ignition switch and cylinder. If you haven't experienced random starting problems yet, they are coming soon. When you turn the key, nothing happens. I thought my 2002 Impala may have been immune to these problems that I've heard about constantly, however, at 90,000 miles, it became "possessed". The symptoms started slowly and got worse. Beside the interior lights flashing like strobs in the middle of the night (while the car was not running), the headlights would occasionally click off and on a few times while I was driving at night.
The relay switch you hear clicking is the Battery Rundown Protection relay. I'm suprised your battery hasn't drained to the point where the car will not start in the morning.
SOURCE: all lights work inside and out except all headlights will not
check the fusebox, mostly fuses are uite easily recognizable by small icons similar to the icons on the switches on your dashboard, find the one for lighting and verify if it is still proper. If not, replace it.
