Spray and flow on Single-handle kitchen faucet running at the same time. Will just replacing the head correct the problem?
SOURCE: Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
SOURCE: moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
SOURCE: The handle on my moen
you must go through the steps outlined here. http://www.moen.com/consumer-support/warranty
