Dear joe, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
