I need BIOS Update file for this motherboard
Go to www.ibm.com check out the support and downloads. They have a lot of updates and manuals.
hope it helps
SOURCE: it shows IBM P6 2001 is that the number if so
That is only telling you the maker, the CPU type and the year.
It is likely to be a NetVista - go to the IBM website and have a look on there.
SOURCE: I am just in need
GO TO IBM WEBSITE TYPE YOUR MOTERBOARD PART NUMBER AND CHECK FOR GHAPHIC CARD COMPATABILITY ARE CONTACT IBM LIVE HELP
SOURCE: what is the minimum power supply for mobo:ibm usa P6 2001?
it depends on what peripherals and processor you're using. If you're using an under 100 watt processor, a 250 should work fine if you're only running one HD, one DVD-RW, and a very modest video card.
The fancier your processor is in it's revision line, the more wattage it draws, the more hard disks, cd-rws, pci cards etc you use.
You also may want to consider uptime requirements, and usage percentage. if you're running constant loads, power supplies don't like that, and the capacitors can get burnt up. Servers, video processing, etc will tend to require more than rated supplies just because 100% use of even close to rated wattage (and you will be very close) will tend to cause the maximum design heat to be produces, possibly blowing out capacitors etc in the power supply, causing downtime.
The brand name of the power supply matters too... if you're using a no-name chinese brand, i would be leery about their "rating", as it's probably peak for only a short time rating...
SOURCE: I have a problem with Ibm motherboard wiring
Het probleem is whera zijn de schakelaar , reset switch , power led en HDD LED Pins?
SOURCE: I have IBM p6 motherboard
cpu is cooked it will not start up. would get new board after that.go on ebay its cheaper that way jim.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
