I cleaned filters thoroughly and still wont heat but everything else seems ok
SOURCE: dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
SOURCE: Hoover TCE660 tumble - no heat
Common faults -
1 The heating elements can fail
(meaning open circuit)
2 There are cut-outs (T.O.C's) that
might need resetting
3 The thermostats (stats) can trip
out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave
programs that can fail and circuitry although most should produce an errorcode
showing you were the fault is.
5 Faultyconnections and burned wires may also be
the fault.
Free tumble
dryer repair videos
We have a Free full video library on appliance repair video’s
SOURCE: My hoover condenser dryer model
Hi Alan....
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
SOURCE: Hi, My 8kg Hoover Tumble dryer Vision HD stopped
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
