SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
SOURCE: fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
SOURCE: water will not drain out
Hi just read your posting.1st you need to drain some of the water by hand using a small bucket or pot ,enough so you can lean the machine back to look under the machine.If you have the old style of pump you will see a red or black fan under the machine front right.If you have this pump turn the fan a few times to loosen it.The fan should turn freely.Then put it back on its feet and select a spin cycle and push start.It should start to drain and then spin.Please reply on how you got on or if you have the new type of pump which has no fan.Looking forward to your reply.
