If moter is working, check drum unit, heating unit, paper feeding clutch, paper exit scencer.
How can I clear error c010
Machine is working suddenly these error is occur can u help me how can I solve
hyjacker alert (ding ding, AaaaUUJUUgggaaa) from, 2012 dark days of computing no less.
You hit the daily double if you win, double pay day.
Toshiba e-Studio 350 Copier
call for service yet=? no really call them.
buy or get the service manual yet, that be first if calling for service is not fun or better.
ever learn to google yet? for manuals free and for same error code, seems not.
the printer is as old AS,2003, 18 years old possible.
"For more information about the error code that is displayed in the Status section, see Operator’s Manual for Basic Function." quote users manual
seems there are 3 manuals. operator, users and service, be wise to have all 3 ,to do self cures, no?
here is what google told me as 1st hit.
https://printcopy.info/?mod=erc&brand=To...
I'd say a tachometer, sensors (optical) is showing a dead shaft on the motor.
lots of causes
wires and connector failures
or the PCB that drives it bad. LGC
it tells also , are the PSU rail voltage at spec on PCB.
and me (learn that power is first in electronics, weak ,dead or full of noise(ripple, or chopper hash)
and for sure things this old the PSU with bad caps make NOISE, and that is hopeless .lacking new PSU.
basically the error means motor does not spin or does so , way too slow.
18 years old ,gee a good run no? even MAGICAL !@@! (an entropy bucking machine, until now)
my hp junk printer the drive gear stripped on the shaft and the tachometer, stalled,
so now it is fixed with super glue. cheap thin plastic hub cracked.
motor good , looked with eyes and ears first. then hear motor spin fast (good) but drive shaft IS dead
I next see the encoder disk (tacho) is dead. and find the gear hub cracked.
HP sells no parts, (so no more me buying their junk) yes off tropic but not buying new a copier. hints .
looking first matters see?
if the motor does spin right (good)
find the sensor tachometer related(not saying i know where it is but is there)
if optical as many are and full of dust, it sure will fail so ever clean the whole copier ?
we use shop air or CAN-O-AIR and blow out all sensors and paper paths.
as you service tech would do first.
clean it first.
18 years of dust? still there? IDK your service schedules or history do you?>
Most likely its jamming on the right side, probably needs new rubber paper feed tires.
Https://www.youtube.com/watch?v=JKWdCKyjlMM
select the link below
SOURCE: que significa el error C010 en toshiba est 280
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
SOURCE: my Toshiba e-studio 3511 gives me a C010 error,
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
