Question about Sony PlayStation 2 Slimline Console
My silver slimline ps2 powers off unless you hold the power cable down, any suggestions?
Annoying it turns off and you have to have the ac cable weighted
Posted by jamesmurray6 on
  • jamesmurray6
    jamesmurray6 Apr 20, 2012
    i got it second hand off of amazon uk last year and its in pretty ggod shape apart from this problem, the guy so;d me it like this, and its been horrible ever since Paid 65 quid and he sold me a broken one !
Wes Cichosz
    New Friend:
  • 28 Answers
Sounds like the solder joints have failed on the board. Either take it to a friend you trust to do this, or if you are comfortable with disassembly and soldering then do so with a sharp tip soldering iron, hand held pen type not the huge gun type. Of course always unplug the power before doing any type of work on it.
Posted on Apr 20, 2012
4 Related Answers
Anonymous
  • 322 Answers
SOURCE: USB headset, Just got new ps2 slimline - satin silver, and I need to know..
as long it a usb you can use any headset
Posted on Jan 28, 2008
Anonymous
SOURCE: Ps2 Disk won't spin unless pressure applied
i had the same problem and i could fix it.
but you i'll have to open your ps2, and then you will notice a little black switch in the on the top of link image:
http://www.richspsxparts.com/howto/lidclosed.jpg
now, open the switch (you i'll see a little wire metal inside) clean the inside part of the switch, and "bend" a little ( til you can make sure that will make contact when the lid is closed) and then close the switch.
sorry for my bad english. =P
i hope this help.
Posted on Nov 22, 2008
Anonymous
  • 265 Answers
SOURCE: My US PS2 won't turn on.
Seems like its just worn out,
i found that PS2 broke after a while, there was a stage were 4 of my mates broke in and around each other
Posted on Feb 16, 2009
Anonymous
SOURCE: ps2 slimline wont stay on red light goes on then off
The problem is most commonly the ac power cord. I have a PS2 slimline and I had a power cord that fit into the slot and was completly similar to the original cord ,but you may need to order a new cord to solve your red light situation.
Posted on Jul 04, 2009
Ps2 power light stays red
hello eric i've repaired a few ps2 most of the time it's been down to the power switch if not the power switch then the ribbon cable attach to the switch
regards
shaun
Feb 25, 2010 | Sony PlayStation 2 Slimline Console
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
Red Power Comes on, but won't switch to green
get an original ps2 u know the fat one they have longer batterie life u obviassly blew yurs out
Jul 14, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slimline wont stay on red light goes on then off
Jul 04, 2009 | Sony PlayStation 2 Slimline Console
Playstation slimline will not let me play my games!
you have to modify first you're ps2 slimline silver so that you can play
by the way,my name is RaLpH B. cAnOn
i'm willing to help you at any time you encounter a problem to you're ps2 slimline silver
Apr 24, 2009 | Sony PlayStation 2 Slimline Console
Disc try is out, no power
pour water on the dic then blow warm air on it with a hair dryer
Mar 17, 2009 | Sony PlayStation 2 (PS2) Console
Black screen, no audio no video
Wow.... Never heard this one before....... I would try using your ps2 with different audio-video cables (maybe just from a friends ps2) If the other cables work than all you have to do is go to your nearest playstation supplier and get new audio-video cables for your ps2. (Walmart Usually sells them)
Hope this helped!!!!!!!!!!!!!!!
Aug 22, 2008 | Sony PlayStation 2 Slimline Console
Ps2 power
you will need to buy a new power board for you ps2 just google it and you can find them there like 20 buck and relplacing them is easy
Dec 25, 2007 | Sony PlayStation 2 Slimline Console
Slimline PS2 Power Problem
What do you have to hold down, the cord from the adaptor to the machine or the cord from the plug to the adaptor? Did you get a shock when you first tried holding the cords down? The cords are pretty thick and the insulation should not peel off at all unlees you are also twisting the cord. Also if you lay the console flat instead of using the stand the problem may clear up, because you won't be twisting the cord.
Sep 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
156 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
