Air conditioner appears to be running but is just blowing hot air.
SOURCE: Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
SOURCE: Air conditioner not cooling
Most likely cause is you have lost your coolant/ freon
These low end unit are generally not worth recharging you can buy a new one for less than a tech will charge you to fix it
SOURCE: fedders air conditioning model a3t12f2ag
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
SOURCE: Our air conditioner is blowing air but not cool
Turn the power off and then back on, canyou here the copressor come on?
