A Friend of mine has a Toshiba Tecra A7. One night her dad forgot to turn it off, (It was on the entire night). When she found it, it was turned off with the power light indicator off, but it was still connected to the powersuply. When she tries to turn it on, the battery light indicator blinks 7 times, and then nothing happens. I found with a multimeter that the power suply is ok ( giving 6A at 15.34 V), and that there is "connection" between the "power socket" and the rest of components.
You may trying pulling the battery out while its unplugged. Another issue may be the socket where the AC adapter plugs into the laptop. Is it loose, broken prong inside the socket. It should have been able to power up at least for a brief moment just on the battery. Hope this helps ya.
I'll try to inspect the socket. About the battery, it's malfunctioning for years, in the last years the laptop only works connected to the ac adapter
Thats a typical laptop battery for ya... if you got 2-3yrs out of it then it was a pretty good battery. They are not very cheap to replace either unfortunately. Be sure to pull the battery out while its unplugged. I've seen a few laptops do this and that fixed it for some reason.
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
SOURCE: Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
SOURCE: my toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
SOURCE: Toshiba Satellite A55 Series S1063
The blinking power cord icon indicates that the battery is not charging, or is defective enough that it is overloading the charger. The laptop will not turn on unless it "thinks" the battery is charged enough to operate the computer. Even though you have the AC power connected and your adapter may be OK, it is still possible that:
Larry
SOURCE: toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Yes, we plugged to the Ac adaptor without the battery, next tuesday i'm gonna open the laptop to check the socket ad the components, and i also will try to plug with another ac adapter .
