Eclipse CD5405 Logo
Question about Eclipse CD5405
What color wire goes to amp
Posted by alandog109 on
What number goes to what color wire
It doesn't work that way! What make/model of fan do you have? How many wires on capacitor? Usually the black wire goes into the L. Always write that info down BEFORE removing the wires & never cut the wires. Also, you have to get the correct switch. Just because it looks the same on the outside doesn't mean it's the same on the inside.
May 24, 2016 • Dryers
Where can i purchase a 4 wire switch
You can't just get a four wire switch & think it's going to work on your fan. That's just a low-end store brand fan so I would need to know how many wires on your capacitor & what slots & color of wire goes into pull chain switch. DO NOT CUT WIRES!
Radio wiring diagram
lost my post. 1 more time. im logged in to alldata.com so can you....!!
there were 6 systems. (orig)
how many speakers.? 4 or 6, with CD and with out, and with external amp and with out,, all have different colors, for antenna motor.
on one setup is wire color P-L (purple,+ ?) (no amp)
pin 9 on radio, marked amp in schematic. and is 8 speakers.
the amp external , used the red wire pin1, not 13 red beep
the red power this amp and antenna motor,
log in and look?
How dou you connect the electical wires I connected them and it throws the breaker
Look at rating plate on motor.
Look for volts, watts, amps.
Figure with Volts x Amps = Watts.
Amps = Watts divided by Volts
1 hp horsepower is 756 Watts.
Lets say you have 120Volt 2hp motor
So 2 horsepower motor draws 1500 Watts
Amps = 1500 Watts divided by 120Volts = 12.5 amps = so you need 120Volt 15 amp breaker with at least 14gauge wire (as long as motor is located within 50 feet of breaker.)
If motor is farther away, then you need 20 amp breaker with 12gauge wire.
Look at circuit breaker rating.
If motor is 240 and breaker is 120, then it will trip breaker.
If motor is 120 and breaker is 240, then it will trip breaker.
If breaker is for 15 amps and motor draws 20 amps then it will trip breaker.
Generally speaking, if motor and breaker are 120V, then black wire goes to black wire; white wire goes to white wire and green wire connects to bare copper wire.
If motor and breaker are 240V, then wire colors can be different. Black-red or Black-white from breaker connect to Black-red or Black-white at motor.
Add a comment. Say the motor rating and color of motor wires. Say the breaker size and color of wires coming from breaker and I will help you wire the device.
1helpful
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
6helpful
Buddy gave me the unit. No wiring instructions, only the leads. Spearkers n ant self-explanatory. Others?
well to give you a quick run down of wire colors:
red: hook to an (fused) ignition wire. pos. (+)
yellow: Goes to a fused constant wire (battery works)
Black: is a ground (-) hook that to the chassis
blue: Amp turn on output (+)... that goes to an amp
the color pairs i.e. white, green, purple, gray are for the speakers, the (-) is the the one with the black stripe... what else would you like to know?
Need to know color code for wires in stereo plugs what wire goes to what component ,,,,,,,i just need a factory diagram to show what the wire colors each one goes to ,,,,,,like to the amp,,,,,which ones...
in most makes and models the red & white are your power, the yellow is the dimmer (if applicable) black is ground, grays, purples, blues, are usually your speaker wires, look at the wires them selves some have writing on them to say what they do, and a wire with a marking on it such as a strip or line is your negative wire (for speakers)
hope that helps
I cant figure out my amp wire color code
every amp is wired the same its pretty easy... the red wire is your positive and needs to be hooked up to the battery.. black is the ground and needs to be touching something metal in your car. blue wire is remote start wire it goes from your radio to amp then plug your red and white rca cables from amp to radio
2answers
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Speaker wire colors
ITS ALL UNDER UR SPEAKER CABLE SIMPLE NEGATIVE GOES NAGATIVE . POSITIVE GOES TO POSITIVE K
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
